ThruTraffic
Oct 07, 2022Explorer
time2roll wrote:ThruTraffic wrote:Ok they are tight. Now check voltage under load.
- Checked connections at transfer switch, socket for shore power, junction where old EMS used to be, mains in RV breaker panel. Checked neutrals, grounds and feeds. All tight.
Could also be the compressor is failing. Get an amp draw on the air conditioner.
Already done both those things. Check initial post.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
