valhalla360
Jan 05, 2023Navigator
ThruTraffic wrote:
From initial post : Problem persists when disconnected from shore power and generator running. Main indicator this is an RV wiring problem not shore power delivery system." If I took the rig to Walmart's parking lot and ran it off the generator and still had the same problems would one believe it was shore power?
Did the generator handle the air/con in the past without problem?
Otherwise, tracing the voltage from the entry point of the RV to the air/con is the logical process to find the issue.
Another quick verification is can a neighbor plug into your pedestal and verify their air/con comes on without problem?
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
