wnjj
Jan 06, 2023Explorer II
ThruTraffic wrote:
Does anyone actually think I've not been measuring voltage during every test or component replacement?
Measuring voltage WHERE?
I've not see you say something like this (with the load on):
I measure 121V at the pedestal.
I measure 119V coming out of the transfer switch.
I measure 118V at the main breaker of the RV sub panel.
I measure 110V at the output of the breaker in the RV sub panel.
I measure 108V at the receptacle.
The above hypothetical numbers would point to an issue with the breaker or connections to it. Notice the larger drop I put in there to illustrate what I am saying? A little drop across each wire and component is normal. If the total drop is larger than you'd expect, one of them should stand out.
