S_Davis
Jan 08, 2023Explorer
ThruTraffic wrote:
I'm done here. Thanks for all the reasonable suggestions. If I ever resolve it I'll come back and update this post.
So was the most of the voltage drop at one spot or small drops at multiple spots? Did you check each connection with your meter, it’s not magic it has to be coming from somewhere. Have you checked the start capacitor on the A/C to make sure it’s not the issue/ what are the rated starting amps and what are they actually. Is the voltage drop at the breaker panel the same or close to what it is at the A/C unit?
