pianotuna's avatar
pianotuna
Nomad III
Jul 13, 2014
voltage drop in hot weather
Hi,
I'm currently in Peachland BC. The temperature today was as high as 41 C (105 f).
I was running the air conditioner on a 15 amp shore power connection. I normally shut down at 109 volts but I decided to observe what was happening. The cord length was 25 feet of #10 and 15 feet of #12. Unloaded voltage was 119.8 volts.
As the day grew hotter, the voltage dropped to as low as 106 volts. I have a watt meter and the only item running was the air conditioner. It started out at 1431 watts (111 volts). At 2:30 local time I saw the wattage going ever higher and decided to shut down when it started (momentarily) spiking to over 1900 watts. Voltage was 107.
This reinforces my belief that surge protectors low voltage cut off of 102 and 104 is far too low.
  • As far as the air conditioner goes, the hotter it gets outside the higher the high side pressure. This means that the compressor will require more power to run when hotter.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
