tlaffourtit
Sep 27, 2014Nomad
found this online. mostly the same info from before.
SPECIFICATIONS
Nominal Voltage: 12-Volt/145 ampere-hours
@ 8 hr. rate to 1.75 final v.p.c.
Positive Plate: Pure lead, low-calcium, high-tin alloy
Negative Plate: Lead calcium alloy
Post Seal: Epoxy-sealed
Terminal: Front access, 1/4" - 20 threaded insert
Container: Flame-retardant, polypropylene -
UL 94 V-0/>28% L.O.I.
Safety Vent: Low positive pressure, self-sealing
w/ flame arrestor
Float Voltage: 2.25 v.p.c. ± 0.01 v.p.c.@ 77ºF (25ºC)
(Range: 13.44 to 13.56 volts per 6-cell battery)
Battery Life: 10 years in float
applications at 77°F (25°C)
Dimensions: 17.58" (446.6 mm) L
x 6.89" (174.9 mm) W
x 10.10" (256.5 mm) H
Weight: 105 lbs. (47.7 kg)
http://www.eastpennmanufacturing.com/wp-content/uploads/0737-Unigy-I-Ohmic-Values.pdf
SPECIFICATIONS
w/ flame arrestor
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
