- pianotunaNomad IIIHi tlaffourtit,
What make and size of batteries? - ok, i'll give it a couple of days. thanks to all. it's great to hear other opinions.
- NinerBikesExplorer
tlaffourtit wrote:
the batteries I have i float at 13.5v. once I disconnect them from the charger; I am guessing they shouldn't stay at 13.5v but drop down into the 12v range? example I had the batteries floating at 13.5 volts for a couple of hours. then is disconnected the charger and took a reading of 12.96v across the 8 battery string. this morning the reading was 12.84v. my question is; it this normal? you responded it depends on the make up of the battery. is there any other information I could get from the battery label to help?
It can take a couple of days for the top charge excessive voltage to dissapate.
Come back in a couple of days and tell us what you got, with nothing attached to them. If you are at or over 12.73V, then you are doing good.
What you are seeing sounds normal to me. - MrWizardModeratorThose readings seem normal to me
- maybe I should disconnect the sting from itself and take individual readings?
- the batteries I have i float at 13.5v. once I disconnect them from the charger; I am guessing they shouldn't stay at 13.5v but drop down into the 12v range? example I had the batteries floating at 13.5 volts for a couple of hours. then I disconnected the charger and took a reading of 12.96v across the 8 battery string. this morning the reading was 12.84v. my question is; it this normal? you responded it depends on the make up of the battery. is there any other information I could get from the battery label to help?
- lol, yes I did. and ty. i'll correct it.
- pianotunaNomad IIIHi,
Do you mean agm battery?
Self discharge can be as little as 1% per month or as great as 1% per day. It depends on the chemistry that the battery maker is using.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
