mena661
Nov 16, 2013Explorer
BFL13 wrote:When my batteries were brand new the charger could get them farther into the 15V range on 2A setting, took some time, but it would get there. Once they got broken in, then the charger would stall out right ~15V. The 10A setting will push it right up to 16V and beyond but I want the batts to take that 15+V until SG gets up to baseline. 2A does do it but I'm wondering if I should stop it when it stops.
I noticed my 1a manual trickle charger can only get the batts so high, but a higher amp trickle charger can get them to a higher voltage before stalling.
when using the Honda gen's DC charger, it stalled out at 16+ v when on Economy but when on full revs it got to 17+ volts on the batts
It must be another one of those power ( Watts---eeeuw) things.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
