mena661
Nov 16, 2013Explorer
smkettner wrote:I had gathered that from some posts BFL did a while ago but not quite an exact number it seems. I'm hoping that the hang means it's actually full. I'll check with the hydrometer tomorrow and report back. If this turns out to be the case on subsequent recharges this will reduce the amount of hydrometer use to periodic checking. I don't use it much as it is but I'd like to take some guesswork out of the maintenance.
Generally at that voltage 1/2 of 1% of capacity in amps would be fully charged.
So pretty much anything below 3 amps (on 740ah) is full charge afaik.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
