mena661
Nov 18, 2013Explorer
MEXICOWANDERER wrote:Thanks MEX, I'll pick up one of these units and try it out.
Everything will rise. I wouldn't try and push the charger much beyond 20 amperes and even that only on a cool day. 2-4 amperes @ 16.2 volts would not be uncommonly seen. The higher the voltage the fewer the amps. But this wattage limit is skewed higher via the incoming (supply) voltage.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
