BFL13's avatar
BFL13
Explorer II
Oct 21, 2019
Voltage Spikes as Gen Runs out of Fuel?
Found this advice for when running a converter off a generator (including inverter gens presumably)
"•Do not run out of fuel! When fuel levels get low the generator will splutter causing the voltage to surge up and down, if this goes too high it will damage components within the Converter"
This could easily happen in my case with my P2200 gen that has no fuel gauge, so I am wondering if the advice is correct about the voltage spikes. Must be others on here who might care too.
--Also, Mex has suggested doing this on purpose as a timer limit for how long to be in Absorption, so that wouldn't fit with this advice.
So what think? Thanks.
