SoundGuy
Oct 30, 2016Explorer
joelc wrote:
I shall also bring it to 132V to see if it plays any role in cutting the voltage or if it is merely for information purposes.
And how would you do that? :h To do this properly one needs some sort of variable voltage source (Variac) ... during my professional years I used one many times but now that I'm retired I no longer have access to one. In lieu of this the best I can do is use the EMS's input trim pot to reduce input voltage to the circuit board that senses and eventually triggers low voltage cutoff. However, that won't allow the voltage to be adjusted upward beyond what the source may be, say 120 vac ... ergo, the need for a Variac.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
