joelc
Oct 30, 2016Nomad
I decided not to try to trip the voltage by adjusting the pot. What I did was kept the post voltage on and shut off all power to the RV by way of the main RV 560A breaker. I then used my VOM to check the voltage incoming and outgoing to the EMS to be sure they were the same. Being said, I then adjusted the pots to the incoming voltage of both poles L-1 and L-2 to the same as the VOM dictated.
I then opened up the main breaker to be sure all areas of measurement were the same. I will wait to see what happens now. If Progressive calls me back I will ask questions. I also recorded the voltages before I made any changes in case I have to put anything back.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
