joelc
Oct 30, 2016Nomad
dougrainer:
What you have mentioned is absolutely correct. I just checked the Neutral and it is good. All other aspects are true and working properly. Since I adjusted the pots the voltage is concurrent with the VOM readings. All seems good at this point. When we get some cool weather again and I can turn on the Heat Pump, I will be able to tell if there are still problems.
What I do not understand is how the pots got out of adjustment.
Thanks all for your help. I am confident we are on the right track. Will keep you up to date.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
