CA_Traveler
Oct 30, 2016Explorer III
Checked the neutral how? One check is to place a heavy load on L1 and then L2 while measuring both voltages and the voltage from ground to neutral. Ground to neutral should be just a few volts.
You may/may not find anything depending upon the problem and/or it may be dependent upon what is happening in the CG. Your best test may be another CG.
