grizzzman
Apr 23, 2016Explorer
2oldman wrote:Calkidd wrote:In reading the FAQ for this controller, it's best used where the input matches the output voltage. Do you have a 24v battery setup?
With having more than just two of these panels should I install one or two more? I have plenty of roof space. I have already purchased the Bogart solar controller
I'm thinking no. You need an MPPT controller, as you've been told. With a monster controller like the Outback you could run 4 or 5 safely in series.
That is for efficiency, not will it work. Efficiency needs to be tossed out the window for what he is doing.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
