Almot
Apr 24, 2016Explorer III
Calkidd wrote:
I have nothing to loose using these panels. I think I will use 3 panels starting out.
Nothing to lose, except for size/current efficiency. Those 208W look same large as mine 245W, and PWM will process less than half of available wattage.
If Trimetric clips it off like - apparently - it says in the manual, why only 3 panels, what is the purpose? To see if solar will make any energy? :) It will. 21A is a very modest system, even die-hard Handy Bob has 2 times bigger equivalent, considering tilt. Enough for a minimalist but not if you want to run your rig on solar the same way as on grid.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
