time2roll
Mar 17, 2021Nomad
All I see in that will be the battery BMS could cut power before the Wagan inverter shuts down at 10.0 volts.
Nothing really wrong with fully discharging a lithium battery. Probably more harm to fully discharging a lead-acid.
What battery do you have?
Although if your solar controller needs a battery connected... having the battery BMS cut off could be an issue.
Just don't run the battery that low no matter the chemistry.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
