jaycocreek's avatar
jaycocreek
Explorer II
Mar 17, 2021
Wagan inverters not suitable for lithium batteries?
I was reading the reviews on amazon for Wagan inverters and wagon CS said there 1000 watt psw is not ideal for lithium batteries with the different voltage parameters..
Is this true and are there other inverters that are not ideal for lithium batteries and especially,what inverter is ideal/the best for lithium because I am needing a 1000-1500 PSW that doesn't break the bank...
  • All I see in that will be the battery BMS could cut power before the Wagan inverter shuts down at 10.0 volts.
    Nothing really wrong with fully discharging a lithium battery. Probably more harm to fully discharging a lead-acid.
    What battery do you have?
    Although if your solar controller needs a battery connected... having the battery BMS cut off could be an issue.
    Just don't run the battery that low no matter the chemistry.
  • 2oldman wrote:
    Thanks.
    Nobody should be allowing their batteries to drain like that. A battery monitor like the Victron BMV-700 is almost a must with Li.
    I don't see the specs for high and low voltage to be much different from any other inverter, although Wagan is not known to be top of the line.
    What's the best bang for the buck then?..Is Kisae considered a respectable inverter?..Trying to get the best one for less than say $250 that will last and do it's job reliably...
    Not in a big hurry but that statement from Wagan confused an already electrically challenged camper..LOL
  • 12v inverters have their "low voltage shut-down" settings at 10.5v typically, with a warning at 11v. Purpose is to protect the battery from being drained right down. Those voltages will be as loaded voltages so after shut down, the battery voltage bounces back to a higher voltage.
    With the higher voltage/SOC of AGMs, SiO2, and LFP you can run the batteries down further before the inverter alarms or shuts down, so there is less protection. That might be what they are talking about.
    Since SiO2 and LFP can be operated to a lower SOC with no harm, this should not matter with them. But it might matter with AGM depending on how often you do that perhaps. Cure for AGM is just recharge at 12.4 instead of 12.2 if that is their 50% and the inverter will only alarm if the load is really big making the loaded voltage really low.
  • Thanks.
    I don't see the specs for high and low voltage to be much different from any other inverter, although Wagan is not known to be top of the line. I will commend them for being honest.
  • Here is the quote....
    Wagan wrote:
    Question: Why wouldn't this inverter work with lithium iron phosphate batteries? Don't you just hook up the wires to the terminals and go?
    Answer: The reason we say its not compatible is primarily because of the different voltage characteristics as the battery is drained. Our inverter is set to 15V high voltage alarm and 10.5 Low voltage alarm.
    These conditions might not be ideal for lithium iron phosphate batteries. Your lithium batteries may discharge completely before the alarm goes off. see less
    By Wagan Customer Service MANUFACTURER
  • time2roll wrote:
    Or is this a charging issue?
    My question also.
  • What voltage is the issue? I think they pretty much all run 10.5 to 14.6 volts and should not be trouble. Or is this a charging issue?
  • Wagan, not wagon. If your computer is like mine, it has been "helping" you again.
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
