Golf_Guy's avatar
Golf_Guy
waking to dead new batteries
I am waking upon to dead batteries on the new house batteries. The last two nights I have been turning everything off when going to bed and waking to not enough charge in the batteries to start the generator. Where to begin looking for problem. Any advice would be helpfull
  • fridge on auto !
    set fridge on LP and leave it there
    you very likley have an inverter
    and the fridge is running on 120vac produced by the inverter
    SUCKING the batteries dead in a few hours
  • A good starting point http://www.solar-electric.com/deep-cycle-battery-faq.html The only way to know what is happening with your batteries is with a battery monitor which measures current going into and coming out. The two current best choices are The Victron and from Bogart Engineering. I chose the Victron and once calibrated can be set to display %SOC (percent state of charge). You do not want to go below 50% SOC. http://www.victronenergy.com/battery-monitors
  • The OP has at least 216Ah's. And a furnace blower cannot go thru 108 Ah's in one night, unless it's running continuously... which it is not.
    After "charging" for 12 hrs, there is no way a 216Ah bank can be anything less than full. And by charging, I mean charging... not trying to float the batteries to full with a converter at 13.6v. If you're gonna boondock, you need a real charger, not a converter set to 'normal' operations. I can charge one of my 215Ah banks, from 50-95%, in less than 4 hours with a 60 amp charger.
    Having to turn the heat down to 45F, and run the genset for 12-24 hrs a day, is absolutely absurd, and completely unnecessary.
  • I came home late, and encountered this thread on the 2nd page. Wow! The avalanche of suggestions is almost overwhelming. Maybe starting with some basics is not a bad way to begin the hunt for the problem...
    • OP how do you rate your mechanical aptitude? Good? Fair? Poor?
    • How do you feel about using a new handheld volt meter the kind with the black and red wires sticking out of it?
    • Do you feel comfortable finding where things are like the inverter battery terminals, and battery terminals?
    • If you are going to be camped or on the road do you have reasonable access to an auto parts store, or Sears store?
    • You need to purchase a meter to do any troubleshooting, assumptions are the mother of frustration
    • Would you feel comfortable going a getting an inexpensive hand held test meter?
  • There is so many reasons to have dead batteries, I wouldn't know where to start.
    These just to name a few..........
    1) charging has never seen 14 volts (batts never seen a 80-90% charge)
    2) like said above, fridge (WH?) maybe running on inverter
    3) furnace running all nite,...starting w/ 1/2 dead batteries
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
