Hi everyone, I'm working on my very first DIY camper conversion, using a 2010 extended Ford E250. Today I have a question regarding wallpaper, I've noticed that some RVs have them on...
In my trailer it is some synthetic material, probably vinyl film. Definitely not a paper. Attached to plywood panel extremely well, I suspect some thermal laminating process rather than glue.
Not sure what you mean by "outside walls". Nobody covers exterior wall outside with wallpaper. There is normally a 1/4" interior plywood panel (covered with wallpaper), then 1.5-1.75" void filled with insulation, then exterior aluminum or fiberglass siding (or a steel sheet in motorhome).
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
