racer4's avatar
racer4
Want advice on series/parallel battery cables size
Hi all,
I need to order some series/parallel battery cables. I have read a lot on this, used many voltage drop calculators, etc. and still would like some more experienced advice.
Here are the details and questions:
Detail 1. I have ordered a Cedar Creek 36CKTS. It has room for four GC-2 6V batteries. It has a electric only residential refrigerator. Pictures of a similar (2015 CC 32RL) setup can be seen Here. Please ignore the fact that the dealer wired it wrong (no parallel cables etc).
Detail 2. I will be supplying four Trojan T-125 batteries. The total battery bank capacity is 480 AH (20-Hr rate).
Detail 3. When the FW is not plugged into utility 120V AC, the refrigerator runs on a WFCO WF-5100 1000W inverter. It claims >80% efficiency. I figure it's max continuous draw (based on 1000W) will be 100A. Actual use will probably be closer to 40A, but I want to size the cables for the maximum possible draw.
Detail 4. I plan to add a 100A converter (Powermax PMBC-ADJ-100 or a Meanwell RSP-1500-15) with adjustable voltage output (set to ~ 14.8V) to do a daily battery charge when not plugged into utility 120V AC. It will be powered by two Honda EU2000i generators, running in parallel. I plan to plug the converter in to an electric outlet controlled by a mechanical timer (thanks Mex). This 100A converter will only be used for generator charging. The OEM WFCO 65A converter will be turned off during gen. charging and turned on when plugged into utility 120 AC electric. I may upgrade the WFCO converter, but that is another matter.
Detail 5. I will upgrade the factory battery cables if needed, at the time I add the 100A converter. It looks like they are 2 AWG, but I am not sure. The pics I linked to above show the dealer used 2 AWG series cables and they appear to be the same diameter as the factory cables.
Detail 6. I will probably buy the battery cables custom made from Genuinedealz unless I find a better source.
Detail 7. The cable lengths are 2' for the parallel cables and 1' (or less) for the series cables.
Question1. What size series/parallel battery cables should I buy? I am thinking 2 AWG minimum, and maybe bigger at 1 AWG, 1/0, or 2/0.
Question 2. What % voltage drop should I size the cables to? 1.5%, 1.25%, 1.0% ?
Question 3. What cable lug should I get? Genuinedealz (see detail 6 link) offers: Tinned Copper Lug OR Heavy Wall Tinned Copper Lug.
Thanks for your help.
Chris
  • I'm more in the camp of 2oldman. You size the cables per how much amperage they are going to carry. 2/0 cables are much more difficult to handle than smaller cables if you don't need to handle the amps..
  • Chris,
    Definitely do NOT connect your batteries anything like the pictures depicted in the Forest River Forum posts. The owner has that all wrong. Lengths of cable between series batteries should be short. Length of cables between the paralleled pairs should be adequate. I didn't see any circuit protection, either.
    I'd suggest to use the largest cable possible for hookups. This is not the place to save a nickel as you will have the most efficiency for the life of the installation. I'd suggest 2/0 cables and that includes the distribution to the inverter and converter. Replace them if necessary.
    Heavy lugs are worth the price. The others are not very stout.
    BTW, 80 percent inverter efficiency is out of the Stone Age. 90-95 percent is typical.
  • 2oldman wrote:
    I don't think the first link is working as intended. I get the site grayed out with a window asking for my email.
    That is a small overlay window asking for your email address. Click the "X" in the small window and the intended post is underneath it.
  • I don't think the first link is working as intended. I get the site grayed out with a window asking for my email.
    I size cables according to what the max amperage will be. Pretty much end of story.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
