CA_Traveler
Mar 21, 2014Explorer III
OnaQuest wrote:X2 I had a bad connection between the cable end and the battery connector into which it was inserted.
If the battery ground cable was getting warm (hot) you can bet it has a bad connection at that point. Check the cable terminal ends where it enters the insulation. If you see any green oxidation, replace the cable.
