Artum_Snowbird
Mar 21, 2014Explorer
A laser beam temperature sensor will give you the instantaneous heat and will show you the problem area quickly.
The temperature will register hottest where it is loose, and then as the heat dissipates down the wires you will see the lower numbers.
The cable itself may have a weak spot in the conductors and it just might not be the connection point. Unlikely... but you said they were tight.
I got mine for $20 from Costco just before Christmas.
