Dusty_R
Nov 03, 2015Explorer
In a stick & brick with the water heater in the basement and with kitchen and bath on main floor, you don't need a pump. All you need to do is tee into the hot water line at the farthest point from the water heater. Then run a return line from that tee to the bottom of the water heater. The water will thermosiphon back to the water heater.
Would this work in a RV ? Good question, I think it would, but not as well as it does in a home with the water heater in the basement.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
