camp-n-family
Apr 26, 2020Explorer
We had an Antigua 195ck years ago that was prone to get leaks from the bunk end seals. Dirt and debris would collect in the lower track and block the drainage. Water would pool in the track and leak into the trailer.
The floors are repairable but the walls are tough. It is rigid foam laminated between the outer skin and 1/4” ply inside. You could try to repair from the inside but you need to make sure the leaks are fixed first and check for mould.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
