lamopar
Sep 11, 2020Explorer
Well I am replacing flooring in my toy hauler and beginning to work under the bed and one cabinet. We have replaced flooring in the back in many places already around the edges. So far we have to replace the floor in pieces. We will put one small section in today that goes under a partial wall going into the bedroom. We add a support board on the outside and slide it in from the bedroom. We also spray undercoating on all the corrugated plastic under the floor and up on the side boards to help keep the water out of them. I always find many pin holes in the plastic. We have to cut screws off under the cabinets and walls then remove the trim and use long brad nails to hold it back in place. Also the large 2X3s that hold up the flooring, we remove the old bolts to the frame and install new ones. I find most of them rusted and break off so they are not much in the line of support.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
