BFL13
Sep 11, 2020Explorer II
toddbailey wrote:
Hey all,
due to a water damaged floor I need to clear out the bedroom of floor to ceiling furniture and ultimately the carpeting.
I'm hitting a brick wall in that I don't see how monaco has fastened the furniture to the floor, walls or the ceiling. Has anyone ever had to do this and if so how do I get the cabinets and end tables disconnected ?
this is a 1990 Monaco 40ft diesel. fwiw.
thanks
I agree with keeping the 1990 you like (note we have a 1991) :)
What is the reason to worry about above the floor to have to remove furniture? Are the walls soaked too?
In a friend's TT I repaired, the soaked, sagging floor (water from a broken WH tank at floor level and a broken water pipe from freezing, also at floor level), I just cut it all away in the open areas, put new 2x4 wood beams underneath into the L frames below (too few metal beams) and new flooring. It was a big job for a DIY, but as mentioned above, you can do it in sections.
The whole kitchen counters etc stayed in place and I got at underneath them as required (not much--the damage was mostly in the open areas).
Without knowing the details in your case, I would first just cut out some floor and see what it is really all about. Then get "creative".
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
