toddbailey's avatar
toddbailey
water damaged floor, Need guidance...
Hey all,
due to a water damaged floor I need to clear out the bedroom of floor to ceiling furniture and ultimately the carpeting.
I'm hitting a brick wall in that I don't see how monaco has fastened the furniture to the floor, walls or the ceiling. Has anyone ever had to do this and if so how do I get the cabinets and end tables disconnected ?
this is a 1990 Monaco 40ft diesel. fwiw.
thanks
  • Typically cabinets are screwed from the outside in, meaning from the other side of the floor, wall, or ceiling. The cabinets go in before the walls go on.
  • I don't own your type rig .... but when I installed new flooring I discovered that my furniture was bolted to the floor - that required me to have someone under the rig to hold the bolt why I unscrewed. May not be the same for your rig but thought this might help. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
