hotpepperkid
Jun 26, 2016Explorer
John Wayne wrote:
I'm betting if you saw water on the roof the drain holes are working, pull the inside frame off and look for a bolt head in each corner snug these bolts up do not over tighten just snug them up. Should fix your problem.
Ah but not always true. Mine would drip (run) and there was water on the roof. Turns out the drain hole were partially blocked. Cleaning them out solved the problem. It only happen in areas where the humidity was really high
