wa8yxm
Aug 13, 2014Explorer III
One of the differences between my Atwood and SOME (At least) Surburan models.
Every Atwood I have seen uses a SINGLE pair of Thermostats, (Main T-Stat and ECO or Emergency Cut Out) this same pair is used for both Gas and Electric operation via the control board.
Surburan may (on at least some models) use TWO different T-Stats. I know they have two over-temp Reset buttons on some models.
This too can be an issue.
Good luck.. Also, if you post specific model I can and will (If I return to this thread) Download and read the manual less you fix it first.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
