Old-Biscuit
Aug 13, 2014Explorer III
pewterman20 wrote:
I think I have a problem with the outside switch as well. I have checked the power all the way to the WH side of the internal switch, and all is well. How do I get in behind the outside switch to check out the wiring? And since I have an internal switch, can I simply remove the outside one and direct wire it?
Is inside switch for 'electric' also?
Do you have 2 switches inside......one for electric and one for propane?
If you have an inside switch for electric YES you can get rid of outside switch.
Outside switch just snaps in..usually end up breaking them when trying to pry them out.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
