js6343js6343
Aug 14, 2014Explorer
I think I have a problem with the outside switch as well. I have checked the power all the way to the WH side of the internal switch, and all is well. How do I get in behind the outside switch to check out the wiring? And since I have an internal switch, can I simply remove the outside one and direct wire it?
On my Suburban WH outside switch, I gently pried is out using a flat head screwdriver. I was able to remove without any damage. I removed and reattached the connections and the problem resolved itself. Probably will have to replace the switch itself someday.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
