boatms03's avatar
boatms03
water heater and furnace issue
I have a 2009 jayco octane t26y. I am having issues with both the water heater and furnace. when I turn on either one they try to light but are unsuccessful the first time I flip the switch. the water heater, an attwood, tries three times then goes into fault. the furnace, don't remember the brand and trailer is at deerlease, makes its three attempts and goes into fault. I have changed the propane regulator and no change. I have removed both furnace and water heater, and all testable parts check out. after I flip the switches on and off a couple of times they both will work. I also have a Olympic grill that plugs into the propane system and hangs on the side of my trailer. I have had problems with it just barely burning, not even getting hot enough to cook on. I am wondering if maybe my gas line is partially plugged. sometimes I can hear a noise in the propane line at the front of the trailer that sounds like the gas is going thru a tiny opening. kind of like a screaming sound.
since it is multiple systems on the same fuel delivery system having problems, I am leaning toward a restriction or something.
