enblethen
Jul 24, 2016Nomad
What is make of WH?
If tank is aluminum, then it is an Atwood and no anode is used.
You maybe able to flush the spring out through the anode or drain plug. Fill water heater then remove drain plug or anode.
No a big deal to leave in tank.
Aluminum and brass should not seize. My guess it is just tight. If there is something to grab hold of, apply more pressure. If nothing to grab hold of, you will need to get an easy out to remove broken portion.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
