ktmrfs
Jul 24, 2016Explorer III
my advice, remove the backflow preventer, it's part of the cheaper water heater bypass with only one quarter turn valve. remove the valve, install the two valve water heater bypass.
the check valve really isn't needed for anything else.
Why remove it?
well, the check valve flow is nonlinear with pressure, so what we, and others have found, is that when you get the water temp right for say a shower, then turn the flow down, water temp changes, usually cold.
The RV dealer we bought our trailer from says they have more trouble with the check valves than anything on the water heater.
Why remove it?
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
