DougMatthews's avatar
DougMatthews
Water Heater barely warm water - NO bypass valve
Need some help.
I have a Suburban water heater (gas only, near as I can tell). Rig is 2008 Weekend Warrior 25' (super light?).
After WH is running for 20 minutes (or more) the water is detectably warm, but not anywhere near hot. Used to work fine.
Seems like all the search results for this type of problem call out the bypass valve as the culprit. This rig does NOT seem to have one (looked at back of WH behind cabinetry - hot, cold, NO bypass).
Winterized by compressed air (thorough purge), removing WH drain plug.
Water system is now full. No leaks. Good flow at faucets. WH fires up, seems like decent flame, gets lukewarm. After it's been running for a while, seems like decent flame (visual inspection), but sounds odd. Causes me to think moisture in gas line maybe affecting amount of gas through jet? Is that a thing?
Any other things I should investigate?
Thanks!
Doug
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
