dougrainer
Aug 20, 2013Nomad
Sooner Schooner wrote:
I called Thor and they were very helpful. I have learned through you all and Thor that the fault light is only for the LP mode. The tech is puzzled why it would be on in the electric mode. I have learned that the water heater is working just fine, he had me run some of the hot water out and then put the switch in the LP mode. The LP heater clearly lit and the fault light is off again for the time being. As long as we have hot water life is good again. Thank you all for your help, you are great people!
The Fault lite should be the SAME light for both LP and 120. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
