Old-Biscuit
May 24, 2020Explorer III
LP System only has 0.4 psi so iof gas is leaking thru gas valve then it is NOT salvageable.
Takes BOTH solenoids to be energized to OPEN the gas valve
When DC is removed springs close the gas valve
Able to light and have small flame at gas valve means it is leaking thru with ONLY 0.4psi
Course you have nothing to loose so disassembling it won't hurt anything
Caution: Gas Valves are classified as NON-Serviceable
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
