dougrainer
May 27, 2017Nomad
IF the welded aluminum heat exchanger tube is leaking, then the odds are the inner tank is corroded also and will probably start leaking also. I would buy a NEW water heater. NOT replace parts or pull and pay to weld. 20 years old, not smart to repair since you will be keeping the RV. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
