boshog's avatar
boshog
Water heater help
In my two-year-old fiver (Montana 3790RD) I have a Suburban electric/propane water heater that is acting up. So my questions are, at this point, what to troubleshoot. I have not yet look at the water heater so this is going to be from the get-go.
The condition it is showing is, when I get to a campsite and after I make all my shore connections I turn on the water heater for electric heating. In an hour or so I have hot water, so far so good. In the morning, the water is luke-warm. The water heater initially heated the water but it does not keep the water hot over time on electric. I can switch on water heating by propane and the water heater cycles as one would expect.
The only thing I’ve check so far is to be sure I don’t have air pockets in the hot water flow. This issue is repeatable removing the possibilities of any resettable switches tripped. It has the marking of a faulty sensor that doesn't trigger the electric heating element once the water temperature cools below a threshold value.
Suggestions on what to look for? I really appreciate any help so thank you.
