TRIPLE8's avatar
TRIPLE8
Water heater issues
HI, brand new camper with a Dometic water heater model # WH-6GEA gas and electric. Dealer is 400 miles away and I'm not leaving it for 6 months lol. Heater worked for 3 days and then quit. I have power from both switches and T-stat going into control board but there is nothing at the 2 amp fuse on the board. I used a jumper from one of the hot wires directly to the fuse and it fired right up. Bought a 2nd board and have the same issues, possibly another bad board? Thanks in advance for help.
  • I only have an old WH but it does have the board with a 2 amp fuse. I think you are saying you by-passed the big plug with the pos wires that goes into the circuit board, and went to the fuse and then it all worked.
    It can happen that plug, if it slides onto the edge of the board, loses good contact. Cure is to pull it off, clean off the contact part on the board and anything in the plug contacts and put it back on. Wiggle it some, see if that gets you contact again.
  • BFL13 wrote:
    Which hot wire did you jumper to the fuse and then it worked? That means the wire or where it is from is no good, not the fuse or the board. Whyinheck would you buy a new board for that? Or else I misunderstand ?
    Hi, I tried the top 3 wires going into the board, the brown which goes to the t-stat, the white and orange from both interior switches. all 3 were hot when the gas and electric switches are on and that is what I jumped from. No power after that point to the fuse. I dont know much about these and assumed it was the board.
  • Which hot wire did you jumper to the fuse and then it worked? That means the wire or where it is from is no good, not the fuse or the board. Whyinheck would you buy a new board for that? Or else I misunderstand ?
    EDIT--which side of the fuse did you jumper to---maybe it is a blown fuse
Having RV issues? Connect with others who have been in your shoes.24,221 PostsLatest Activity: Feb 23, 2025
