RJsfishin
Dec 01, 2015Explorer
Use sealer or tape on tapered pipe threads only.
Any other fitting does not use a sealer.
It may be a rubber seal that has deteriated.
Take it apart to see what you are up against, but do it when you have access to a hardware store,
In the meantime shut off the water to the heater, or turn off the pump.
