Lantley
Mar 26, 2017Nomad
Yes that is a thermistor . It is designed to trip based on heat. If there were a fire or flames it is designed to trip the circuit, similar to a fuse but it detects heat not current. They are notorious for acting goofy and creating a poor connection. I imagine the RV industry does not use the highest quality thermistor.
As test You could just take it out of the circuit and see how things work with out it.
The circuit will work just fine without it. replace it if it is defective.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
