DrewE
Jul 18, 2016Explorer III
Boon Docker wrote:
The aerator screen on the faucet could be plugged, unscrew it and see if you get a good flow.
Probably not in this case, since the cold water works well. There are not too many heat-sensitive things that can clog an aerator screen.
I can think of three reasonable explanations:
1. Water heater check valve, as described by others.
2. Water heater bypass valve(s), either misinstalled or misconfigured.
3. The water heater is not yet filled. (This may be a long shot, granted, but sometimes the simplest problems are the hardest to suss out!)
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
