BFL13 wrote:
Old-Biscuit wrote:
Teleman wrote:
Cleaned the multipin connector on the board and it fired right up. Indicator light still isn't working but a minor issue I'll address later.
Light on On/Off Switch is a FAULT Light---should come on when:
*Propane Flame Fails to light/fails to prove it lit
*ECO has tripped (failure of normal temp T-stat)
Reset Fault Light...turn switch Off then back ON
It seems odd to me that Atwood would change how that on/off switch works with the red light. Must be confusing where it does one thing with some models and another thing with other models.
I have the Direct Ignition GH6-6E except with a newer control board and flame sensor set-up. The OEM red light works the same though. It comes on as soon as you turn the switch to "on" and it goes out when the heater starts (when you hear it come on) After that, if there is trouble and it does not stay lit the red light comes back on. (now acting as the fault light)
However the manual's schematic calls it the "Non-Ignition Light", but then says in the instructions for starting after you turn the switch to "on", "If the switch light stays on longer than 15 seconds, place the switch in "off" and wait 5 minutes" and try again.
The red light and switch worked the same way with the Suburban WH we had in the 2003 5er, except ISTR there was something about 3 tries, I forget details of that 3 tries thing.
1991 and a 6E are 19-20 yr versions
Little changes were made with each new version.
Then in 2004 they went to a DC Control for Electric/Gas Version
(10E/6 gal and a 4E/10 gal)
Now for 2020 they have a NEW 6gal/9gal XT Model that has the Electric Element access in outside compartment.
Time marches on...new versions...new control schemes
