cekkkExplorerOct 02, 2018Water heater odorDW says that the hot water smells. Plan is to drain it and introduce vinegar by "winterizing" but not bypassing the WH. Q. Good plan? Q. How much vinegar before filling ten gallon tank with water?...Show More
Dusty_RExplorerOct 03, 2018I would bet that it's the anode rod in the water heater that is causing the smell, try changing it, or just removing it.Dusty
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentAtwood water heater problemSmelly Water HeaterWater Heater Replacement RecommendationsWater pump?Suburban SW12DEL Water Heater On/OFF switch melts???
