Yes, I cleaned everything, male and female. 320 grit, lifted the female pins in the plug, etc.
Riddle me this. If when I connect it and it finally lights, I wiggle the plug, wires, etc, it does not shut off. If the contacts were bad or dirty or corroded, it would lose contact and shut off, but it doesn't. Thus the connection has to be solid right?
All I am doing is unplugging and replugging, sometimes it fires and sometimes it doesn't. If it had to do with the switch or other connections wouldn't it either work or not? The switch doesn't move once it's on. I don't get it. I'm going to clean and check ALL connections just in case.
