I went to use my hot water this weekend and nothing came out of hot side, turned faucet on and nothing came out, water tank is full, anyone have any thoughts?
The check valve in the water heater HOT outlet has failed. It is in the fitting on the tank (top one). They are junk......cheap plastic plunger/spring/o-ring assembly,
O-ring dislodges, plunger gets cocked, scale/calcium builds up etc.....no HOT water flow out of water heater.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 24, 2026
