Hornnumb2 wrote:
The water heater is on the front corner by the tanks, I will get the soapy water and see what I can find. Thanks
Being on the front corner near the tanks, it is possible that the tanks and hoses could be the offending part. Air movement could cause the odor to be noticed by the hot water tank.
I was on a trip through Alberta a few years back and had the odor of propane near the front. I wasn't able to pinpoint it exactly until I got the squirt bottle and soapy water out. I was shocked to find that I had multiple leaks, The hoses from the tanks, the regulator and the feed hose all showed lots of bubbles with the soapy water.
So I went the nearest RV store I could find and replaced everything from the hard steel pipe at the frame right up to the tanks. All new for peace of mind. I forget what I paid but it really wasn't that much.
And here is another one. The rubber line from the regulator to the steel pipe went through the tank holder base before it went back to the steel pipe. Where the hose went through the tank base, it had been rubbing on the metal of the tank holder and the hose was worn considerably. :E
When I installed the new line in the same place, I got a piece of heater hose, slit it lengthwise and secured it around the propane line to protect it from abrading.
I suggest you look at all this too.
